Passenger Seat Belt Warning
2018 Silverado 2500 HD
The passenger side seat belt warning for failing to fasten does not chime and there is no display on the center overhead console as page 86 of the owners manual says should be there. Dealer says it is not included on this year model of HD truck. ALL of my other vehicles regardless of manufacturer have had a seat belt warning for all front seat passengers for many years. I would think this system is a mandatory item by the NHTSA.
Is it a regular cab? With a “off” switch on the dash? Not sure if they are still this way but my 01 is. The switch is so you can disable the airbag if you have a child seat in the truck.
Did you buy it used? If so there is a plug under the seat make sure it’s plugged in. Some people have been know to unplug it so the reminder chime won’t chime... I plead the 5th...
IIRC, as it was many years ago since I owned a 3/4 ton, that 3/4 tons and above were exempt from the seat belt laws thus that may be why the passenger-side does not chime....just guessing.
Wforest08,
Bought the truck new as first owner. Nothing unplugged or disabled by me. No dash switch to turn off either.
dougwtx,
That may be possible but a Dodge 1 ton I traded in and my neighbors 3/4 ton both have working passenger belt chime warnings.
Thank-you both for your input.
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
    • It’s never dry here but it gets hot. My 4 vehicles I keep at home drive an 18 mile loop. One 6 days a week. Two about 3 days each and one once a month. Only one goes on trips about 4 times a year 1000 to 2000 miles each time. One 26 years old gets driven once a month for 22 years. One 14 years old goes 6 days a week. The other two are recent at 2 and 4 years. All are performing normal no extra service other than that would be half of recommended or severe service in the maintenance manual. No extra water or steam out the exhaust or premature plug wear. I would consider an 18 mile loop would be enough. So apparently once a month at 18 miles for 22 years has kept the collector car running well. About 45 minutes a month.
