Removing chrome.
Love my new truck but it's got a bit more chrome on it than I'm comfortable with.   The trucks is red tintcoat. Not sure if I like black or aluminum rims on it.    Anyone have pictures of theirs?   Anyone have one they removed all chrome from?
Also anyone want to swap chrome for black bits?   Kicking this idea around but if anyone's interested let's talk.
Same style color but inward thinking of brushed aluminium look. It's just wd40 and a scotch right pad.
Where are you located, and what pieces are you considering swapping?
Located in New York. I'm not sure yet.
Thinking of mirror caps,. Window trim, wheels so far
