I have a 2018 Silverado 2500 HD LTZ Duramax.  The truck is pretty much fully loaded and I don’t like the center console.  The 1500 truck I used to own had the front bench seat; actually two buckets with a center seat that the back can fold down to be a arm rest/console.
Has anyone converted the center console to the front “bench” seat?
I would like to make the conversion but am wondering what’s involved and are the parts just a bolt on?
Any link to anyone that has done it too would be appreciated.
Thanks
The middle is the only difference, you may have a subwoofer that may need to be relocated.  I have the middle seat, the best part is being able to pass thru and the middle seat bottom is a big lockable storage box.  That and the top box makes it really nice.  In the top box are 2 USB ports and a 12v plug so there is wiring there too.  I'm sure it can be done but it may cost a lot.
Thanks
Maybe you could find someone who wants to switch. Last year I wanted to switch to the center console you have, I have the bench seat, but couldn't find anyone. There are some guys on here who have done the conversion.
Sent from my SAMSUNG-SM-G935A using Tapatalk
advertise a trade,   you will quickly get responses I am sure.
I’m currently in the process of this exact swap, so far it’s been a direct bolt in. The console and jump seat use the same mounting location, there is a dash piece you will be missing and some trim can order from gm that fills in where the console was, it was about 100 shipped, that includes a 110v plug and cigarette type plugin if you already have it. Still working on the wiring, but I was planning on removing the connector on the console and extending the wires to run under the carpet to the jump seat, I will have one extra dual usb that was on my console I’m planning on relocating to the glovebox
Curious how this turned out I was looking to do the same thing but can never find a console that doesnt cost an arm and leg
  • 4 months later...
Does anyone have any idea if this swap will be possible on a 2020 2500HD?  I've got a family of six.  Getting the bench seat from the factory severely limits what options you can get on the truck.
Christian
Thanks
I would definitely trade you for your center console for my center seat! If interested let me know!
have you sold your center console yet?
  • 5 months later...
Christian
What a joke gm wont let us family of 6 guys order a nice truck with the 60/40 front. Very stupid business! I was trying to build one one the web site and if you add anything cool it gives you that stupid “must remove 60/40 bench seat” message ? I’m a die hard gm guy but that’s idiotic
I found a Trim shop in Bozeman, MT that was able to swap my console out for a factory bench seat in my 2020 Denali 2500. He documented the process so that it’s easier the next time around. Let me know if you want his contact info. He’s good stuff.
What’s the plan for the missing carpet where the console was?
The trim guy said he could replace that portion of the project but I decided to not do that.  The GM rubber floor mat for bench seats covers that area completely.
Christian
I think the subwoofer and other electronic boxes are mounted under center console. That's why certain options aren't available with the bench seat.
    250.6k
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 258 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
