There are multiple videos showing how to replace ignition cylinder lock.
PROBLEM & TIP:  If you go to reinsert the new lock cylinder and it won’t go in all the way, only hits metal on metal,  look inside.  The rectangle “female” end inside has to line up with “male” on new cylinder.  Mine was off and I had to insert a flat head screwdriver inside steering column to turn “female” end to match angle of new cylinder going in.
