Seems like on my 2020 Sierra 2500HD awhile back when any of my three trailers were plugged in and the truck was turned off the trailer lights would only flash every 30 seconds or so? Lately it's almost a constant flicker with any of the trailers.
I get the flashing lights for security, but mine flicker irregularly and every second or two, almost like morse code. A few posts i read said they were getting a flash every 10 seconds.
  • 8 months later...
On 6/26/2023 at 9:21 AM, MrMagloo said:
Same here.  Appears to be the Trailer Connector security feature.
I dont like the flickering but this says we can at least set it to one blink every 42 seconds instead of the constant light show!
https://gm-techlink.com/?p=14165
  • 5 months later...
On 5/2/2019 at 8:14 AM, Rsktm300xcw said:
That link is very informative and would have been very helpful to me about a month ago. I through a ton of trial and error figured out that my trailer lights need to have just the right amount of load for everything to work correctly. A little tip, if you have LED lights and are seeing error being detected by your trailer light test adding a resistor to the circuit fixed my brake light problem. On my running lights circuit my trailer had 17 incandescent lights and they would all turn on for 1 second and then turn off every time I tried them. The trailer test showed a running light problem. I swapped all 17 out for LEDs to reduce the load and that seems to have solved my problem. So it is very important to reach the right  balance for the trailer light control module to see enough load to know that the light is working but not to overload so the module shuts the circuit off. Can be tricky. There is also an update out to "reflash" the module. I dont remember the number but it listed near the end of the cold weather electrical problem thread. My local dealer did the update as well. So far dont seem to have problems. Waiting for first long trip with the trailer to see if it is all solved.
What circut did you add the resistor, and what resistor rating did you use? THanks!
    ncleg
    ncleg
  • Who's Online   4 Members, 0 Anonymous, 693 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
