New to me 18 Sierra
I just picked up a slightly used 2018 Sierra and I had a question about two different things I was thinking about doing.
Number one is about a front camera. I have the SLT model obviously with backup camera. If I buy a camera for the front, is it as simple as connecting it to the back of the radio? I assume there’s a plug there? Do I need a new radio? New programming?
Number two is it has an ARE cap on it. I’m contemplating running one or two strips of LED lights on the top so I can see in the back better. I plan to have them on a switch in the back, but what I was wondering is if there is one that has either different brightness levels or perhaps white and red LEDs that you could switch between?
Thanks for the input!
For the front camera, you’ll need the interface module as well as the front camera.  The GM backed one is made by Echomaster and runs about $500 for the interface module and front camera.  The same interface module can be used to add 4 cameras.  Camera locations typically are front, left mirror, right mirror, cargo lamp, and wireless for the rear of a trailer.
I saw the 500$ one on the GM accessories page. So in theory I can buy that and it has everything I need to have the front camera integrate with my radio display?
Thanks for the info!
I have not actually purchased it, but I did look into the kit and read the install instructions.  I believe the $499 kit will have everything you need to do the install (harnesses, modules, and camera) and requires no re-programming of the OEM installed modules.
