Sub frame coating and rubbing
Went shooting this past weekend and had to drive up this really bumpy and ditchy path and I rubbed my sub frame and so e of the coating g rubbed off. Is it a big deal? If so can I get it repsprayed or however it was applied? And it seems that I may need a lift since it did rub. How many inches should I go? Or should I just get a level kit. Ground clearance wasnt that great. Any input will be greatly appreciated
1 hour ago, wforrest08 said:
This thread will show you what you want to use to touch up the wax coating. NOX-RUST® X-121B
Thank you very much
8 minutes ago, HondaHawkGT said:
This is the coating used on the frame.
https://www.daubertchemical.com/products/corrosion-prevention/product/nox-rust-x-121b
You can buy it direct from them. Do not use a rubberized undercoating on the patch that's missing. Rubberized undercoating products are terrible for spot coatings.
care to expound on that more? is your link a "rubberized undercoating"? im a little confused here with your phrasing...or are you meaning using other rubberized coatings NOT daubert X-121B
No my link is to the original factory wax coating.
I'm just adding a cautionary note in case somebody reading this thread and decides to just use whatever rubberized undercoating spray they found at the auto parts store. It's the worst stuff you can use for repairing spots on the frame.
that makes sense! i read into your comment the wrong way. Thanks. Just picked up 3 cans of the wax coating from Daubert
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 812 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
