2014 owners Help!
I have a 2014 LTZ that doesn't say Driver 1 or Driver 2 anywhere on the DIC (digital info center) or anywhere for that matter when I start my truck or use my Keyfobs to unlock my Truck.
Can someone please confirm that their Truck shows a Driver designation (1 or 2 or?) when they unlock and start their truck?
I am thinking that maybe I need a dealer to program the driver designations with their scan tool?
Also I think this my be why my memory seat function does NOT work as there is NO Driver programmed to remember the positions for.
Any advice?
Thanks!
Any advice?
Thanks!
Try one of these:
Programming with Two
Recognized Keys
To program a new key:
1. Insert the original, already
programmed key in the ignition
and turn the ignition on.
2. Turn the ignition off, and
remove the key.
3. Quickly, within five seconds,
insert the second original
already programmed key in the
ignition and turn the ignition on.
4. Turn the ignition off, and
remove the key.
5. Insert the key to be
programmed and turn the
ignition on within five seconds.
6. The security light will turn off
once the key has been
programmed.
7. Repeat Steps 15 if additional
keys are to be programmed.
If a key is lost or damaged, see your
dealer to have a new key made.
Programming without
Recognized Keys
Program a new key to the vehicle
when a recognized key is not
available. Canadian regulations
require that owners see their dealer.
If two currently recognized keys are
not available, follow this procedure
to program the first key.
This procedure will take
approximately 30 minutes to
complete for the first key. The
vehicle must be off and all of the
keys you wish to program must be
with you.
1. Insert the new vehicle key into
the ignition.
2. Turn the ignition on. The
security light will come on.
3. Wait 10 minutes until the
security light turns off.
4. Turn the ignition off.
5. Repeat Steps 24 two more
times. After the third time, turn
the ignition on; the key is
learned and all previously
known keys will no longer work
with the vehicle.
6. To learn a second key, turn the
ignition off, insert the second
key to be learned, and turn the
ignition on.
After two keys are learned, the
remaining keys can be learned by
following the procedure in
Recognized Keys.
The key has a bar-coded key tag
that the dealer or qualified locksmith
can use to make new keys. Store
this information in a safe place, not
in the vehicle.
See your dealer if a replacement
key or additional key is needed.
If it becomes difficult to turn a key,
inspect the key blade for debris.
Periodically clean with a brush
or pick.
With an active OnStar service plan
Any advice?
Thanks!
My 15.5 DenaliHD does not show Driver 1 or 2 and memory seat function works fine.
My 14 LTZ does not indicate this. I thought the seat recognized the FOB based on my wife’s suburban. I only have one FOB for my truck so can’t compare.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   4 Members, 0 Anonymous, 719 Guests (See full list)
