T.S.B. for the 70 m.p.h. shake
I looked at the other posts but didnt see anyone ask.
Brand new truck a week ago and it has the dreaded tire shake around 70 m.p.h. It has almost 600 miles on it. Is there a T.S.B. for this ?
It's a 2019 2500 HD double cab 4x4. It has the 20" wheels with good year wrangler sr-a's. I should have just kept my 09
Thank you.
Do a search on this forum. Many threads. Road Force balance the tires. Goodyears are notorious for the shakes.
hopefully you can get the dealer to swap out to another MFG.  even that's not a sure thing, i went through almost 2 sets of continentals to get it to acceptable, its still there, just not as bad as it was.  If i was to do over again i'd go Michelin tires
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 277 Guests (See full list)
