Replacement turn signal switch
I have a 95 k1500. Neither of my trunk signal work. I don't even get the green flashy arrow on my cluster. So I believe my switch is bad. The arrows and all lights flash when hazord is on. Is it ot switch? And if so all the ones I see say with cruise control or no cruise and no tilt. I have tilt steering but no cruise control so witch one should I use?
Your truck may still use actual turn signal flashers. It sounds like the one for the signal lights might be bad, if equipped. It also could be a blown fuse. Turn on the 4 ways and feel around under the dash for the flasher, it may be in the corner of the fuse panel, its about the size 6 quarters in a stack. When you find that one swap it with the other one under there and see if the signals work. If its not located in the other corner of the under dash fuse panel it may be in a clip fastened under the dash somewhere. Good luck.
So I looked at my switch and I have cruise so I'm a idiot for not looking first lol anywho, if it was a flasher wouldn't the lights just light up and not flash? I have no turn lights not even the pretty dash arrows
I have seen flashers go bad and nothing works, but I'm not sure if your truck uses flashers. Later models flashed through the BCM. I'm just saying it might be worth while to check to see if your truck uses them. When you unplug the flasher, check make sure you have battery voltage on one of the terminals with the key on. If so the signals should work if the flasher is good. If no voltage, check fuses. The 4 way flasher will be easy to find, if equipped, just listen under the dash with it flashing and feel around until you find it. Maybe someone else on here knows for sure if 95 models used flashers or not. I would check fuses and see if I had flashers before I ordered a switch.
