Hello all, I have a 2015 Yukon Denali XL and recently did a trans fluid and filter change. I’m a bit restless with the exact fluid level since I wasn’t sure of the exact trans temperature at the time of refill (between 95-113). Is there a way to see the current transmission temperature on the display without having to use the little gauge ( estimating)? Thank you in advance.
Yes, just push the trailer knob located on the gear shifter and it will display transmission fluid temperature at the speedometer.
Release when finished
Thank you. I tried everything else besides being in tow haul mode. Thanks again.
No problem [emoji1303]
10 hours ago, SARNCAN said:
Hi Sarcan,
so I’m in tow haul mode and going thru the different windows in the instrument cluster and all I get is the small transmission gauge, not an actual screen for the temperature. Any suggestions?
Hi Sarcan,
This is how to check transmission fluid temperature, it is the first one to the right.
Each dash is 25 F .. so 100/125/150/175/200/225/250/275/300 degree Fahrenheit
  • 4 years later...
1 hour ago, Juan Avulos said:
Hola a todos mi Yukon Denali 2015 después de unas millas hace unos jaloneos al desaselerar y acelerar corriendo alguien me podría ayudar
Translation:
Hi all my 2015 Yukon Denali 2015 after a few miles does some pulling when decelerating and accelerating running someone could help me.
    • Ahh, sorry about that - I got some bad info. Newdude is correct. That's what I get for working 13 hours straight ... on my "vacation", lol.   Should've checked the files I had instead of the internet.   Anyway ... this is GREAT news, since this would've been an absolute friggin nightmare to get working.   I don't think the lack of VVT is causing this - you've got another issue. Wiring, I'm betting.   I'm telling you right now, your computer isn't bad. If it worked before the swap, it's working now. You need to do some more (better) diagnostics and figure out exactly what you're missing. Did you test every wire directly at the MAF? Have 5V reference? Ground? If you're reading ZERO g/s, your Hz isn't much use - it's going to be the wrong value anyway. The MAF is not working, and you need to find out WHY.   I got this off the net, so VERIFY first: Pin A: Black (BLK) wire, Circuit 552, serves as the Sensor Return (Ground).  Pin B: Tan (TAN) wire, Circuit 472, carries the Intake Air Temperature (IAT) signal.  Pin C: Yellow (YEL) wire, Circuit 492, is the primary MAF Sensor Signal output to the PCM. Pin D: Pink (PNK) wire, Circuit 339 or 539, provides Ignition 1 Voltage (Power).  Pin E: Tan/Black wire, Circuit 552 or similar, often associated with the Intake Air Temperature ground or signal return.  Global-A list: https://postimg.cc/KKJnQC85
    • Correct....the end user can't reach to Realtruck directly like they can if they purchase a Bak, Undercover, etc...  It has to go through a dealer.
    • It is 4wd. shop told me it is the slip yoke. But not sure.
    • No, I did not tune out vvt. From what I read it should still be able to run without it, it'll just lose some torque/power.    I can see how that would make it not run correctly, but why would that cause the faulty MAF readings?   EDIT: I just ran a quick test and checked, and as I expected, the computer sees that the VVT cam phaser solenoid is not present, and throws a code for it, and does not try to change the cam angle at all. Commanded position just remains at zero, 100% of the time. This makes me think that the VVT is most likely not the cause of the problem though if anyone has a different/better explanation, I'm all ears.   UPDATE: I was able to find that my scan tool does indeed support reading the frequency (hz) off of the MAF (I thought it wasn't supported but turns out I just didn't know where to look for it). I noticed that regardless of engine state it always however this Is not what I observed with my multimeter. Like I said before, the MAF seems to put out a normal signal during cranking and then the signal drops to a very erratic reading once the engine is running. It seems from what my scan tool is telling me that the ECM is not recognizing this at all, and just reads 0 Hz 100% of the time. This pushes me towards the the PCM itself is faulty. I I have the PCM out of the 2007 donor vehicle, which I may try to connect and program (it's only ~50 bucks to get the software for a one-time programming)
    • Did you tune out the VVT?  07-09 they did not have VVT.  2010-2013 they did.      If you haven't tuned it, its trying to adjust cam timing.
