High mileage oil??
Hey all,
Getting ready to change oil in my 99 gmc. And while at the store I saw penzoil now has 5w-30 oil for high mileage over 75,000. Well i'm at 76,000 in my truck and just wondering if this helps or does anything better then there standard 5w-30 oil. It's $3.50 more for the 5 quart .
thanks alot!!!
I used it in the blazer, never really noticed a difference in power, or leakage, or smoke, or anything, but I always figured, that a couple of bucks more, is worth it if it'll make my engine last a few thousand miles more. but as far as performance wise or leakage...no it didn't seem to help any. but I still buy it......it's still cheaper than synthetic
It's all about marketing IMHO; I run a heavier weight oil in my higher mileage vehicles. IE; my 89 K2500 @ 133K gets 15-40W while the wifes 99 burb with 75K still gets 10-30W, 5-30W in the winter; more important to use a grade consistant with your ambient temps.
Always did make sense to me to put a heavier weight oil in an engine that was showing signs of wear but I was wondering if they were actually using a different additive package in oils advertised for "higher mileage engines".
Maxlife does use a different additive package. I am unsure about the other brands, they just might be a heavier oil. visit www.bobistheoilguy.com and click on forums. Anything and everything you wanted to know about oil is in those forums.
Maxlife initially had really good additive package, but I think that it has been changed slightly recently. They lowered the amount of moly. in it or something like that.
If it were my truck, I would run a mild ester cleaner thru the oil such as auto-rx and continue to use the oil that you have been using.
Good luck.
I agree with RossT got to bobistheoilguy and check it out. This link will take you to the forum section. There is a ton of lubrication information on that site.
I have used Auto RX and it works well. The best part is it works slowly but efficently. :thumbs:
I have never owned a car in my life with < 75,000 miles and I've never had any oil-related problems using regular oil up to 200,000 miles.
IMO, like many things in life, it's just a marketing gimmic thought up by the marketing people in a large corporation in the hopes that their useless product will bring more of your hard-earned income into their pockets so they can afford bigger houses, more expensive cars, and that membership at the country club.
From what I can understand about these "high mileage" oils is that they have an additive to swell the seals & gaskets, preventing leaks.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
