GM/GMC interior accents
Hi I am new member to this site but have been following posts on this site for quite awhile, Iam soon to be the owner of a 2019 Silverado 2500HD LTZ Z71 in Australia I have just sold my 2007 Classic extended cab Silverado 2500HD I have had since new and can only hope that the new one will give me the same reliable service.
My question is does anybody have any good photos of the different wood grain inserts that are in the High Country and the Denali, I am particularly interested in the darker colours quilted spalted maple, mineral caster and I think the grand momiji is the standard in the High Country. I have searched everywhere to find decent photo,s but to no avail.
The colour of the truck is graphite mettallic with black trim with the standard silver looking inserts.
Jeff
This is what I have.
Thanks for that Phil! I have been following your towing mirror upgrade as well but may run into problems as the company doing the conversion (left to right hand drive) are using some module to make the standard LTZ mirrors work and tell me that the towing mirrors won’t power fold.
Ooooh.... I’ve yet to see/hear about a Left to Right Hand drive. What can you tell me about the truck? What year? Have a list of the RPO codes? What issues are they running into?
Hi Phil they are 2018 upwards Silverado 2500HD LTZ Z71 trucks they are being converted to RH drive by HSV in Australia they are also converting the Camaro look it up on youtube. I have been following your mirror conversion post and have a set of powerfolding DL3 mirrors genuine and the genuine harnesses I dont have the truck yet so I cant confirm what they have done in the doors but have been told by a tech from within HSV that they are using modules to make the Left door think its the right and the right think its the left yes sounds confusing but also because of what they have done the DL3 mirrors will not powerfold so I have been told. The DL8 mirrors which are on the truck standard only power fold from the door control. The trucks they bring in dont have DL3 mirrors so when I get inside the doors I will be able to see what they have done I believe they have gone down this road to save money on the conversion process.
Back to my original post thanks for those pictures and do you have one of the spalted quilted maple?
Jeff
    • Oh yes, someone is going to be certainly hitting up GM service/ support for a 20 year old truck.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
