Lower control arm ball joint help
Can the lower ball joint on a 2016 Silverado crewcab 4wd z71 off road package stamped steel be replaced without changing the entire arm? If anyone has done this can you give me info on the replacement ball joint. Thanks
Not sure if you would be able to source a replacement ball joint since it is serviced with the entire lower arm. 2nd thing being is the cost to pay someone's labor to do this would probably be a wash, not to mention you're also getting new bushings at the frame side as well.
Really is a wash. Even moreso if the truck is a 4x4 as the cv axle still has to come out along with the strut assembly. And the price you pay gor a complete control arm with new bj and bushings isnt that much more on rockauto.
Sent from my LG-G710 using Tapatalk
Part is 300$ if i can find a ball joint that will fit. I will be doing it myself.
Where are you looking? Cheapest well known name brand.22344c96843e673612d76871d732e847.jpg
I have off road package this is where the whole issue lies. Stamped steel with off road package. Its a lil confusing with all the different arms and joints out there.
5d018f2865396_Screenshot_20190612-194527_SamsungInternet.thumb.jpg.163224509e3a098c103de7ad70805168.jpg
Ok do yours look like the two in the middle? Just tryin to help as ive been in your shoes tho mine are the first style lcas.ff79bc9a5bb457b1b11635d2eba79453.jpg
Well thats the cheapest ive found on a solid seller and well known brand. I get where your coming from that does add up. I'll say this though. Given the issues with the upper lcas snapping at the bj id go aftermaket lcas or ucas. Seems to be the weekest link besides the bjs themselves.
    • Thanks, all. It sounds like keeping the software "as is" is the best course of action.
    • https://en.wikipedia.org/wiki/Overengineering   Excerpt from the above link: (BTW the above is a 90 second read)   [Quote]   A story about very precise engineering is given in the 1858 story The Deacon's Masterpiece or, the Wonderful "One-hoss Shay": A Logical Story by Oliver Wendell Holmes Sr., which tells of a carriage (one-horse shay) Because it had been engineered so that no single piece failed first – no piece was over-engineered relative to the others, and they thus all collapsed at the same time. A similar quote by Ferdinand Porsche claimed "the perfect race car crosses the finish line in first place and immediately falls into pieces."[5]   [End Quote}   By Engineering's  own definition then; the AFM and Torque Converters, 4-5-6 clutch assembly of the 6L80E, and a dozen other common chronic parts and systems failures are "UNDER ENGINEERED". And by their own definition done so with INTENT. Ya can't have it both ways OEM's.
    • Everything you need to know..... https://www.gm-trucks.com/forums/topic/198157-2014-2017-dl8-dl3-towing-mirror-upgrade-–-mirrors-explained/
    • I was in Utah this week attempting a bow hunt in the Wasatch mountains with friends.  On the evening of the first hunt, making my way across a ridge to a friends camp, the upper control arm on the driver's side separated, the CV axle got trashed, and the wheel was dang near at a 45 degree angle to the ground.  I was able to get it towed off the mountain and into town about 3:00 am, and spent the remainder of the night in an O'Reilly's parking lot.  Luckily, there was a Chevrolet dealership not to far away so I was able to get to the dealership and pick up a new CV and UCA.  It would have been a few days before they could have gotten to the truck and I brought tools with me on hunt since it was a two day drive to get there, so I did the repairs myself in the O'Reilly's parking lot.      What's interesting is that the UCA ball joint didn't break, it just popped out of the bottom of the UCA.  There was VERY LITTLE evidence of grease on the ball joint or in the socket, and you could see where the ball joint had warbled out part of the socket over time.  I guess that's what happens over 186K miles of use :)   Big Kudos to O'Reilly's for letting me work on the truck in their parking lot.  However, they made a $150+ off of me from the purchase of various tools, so I guess it was in their best interest anyways :)   Getting towed off the mountain.   UCA Ball Joint Socket   Trashed CV   Suspension disconnected and UCA and CV Removed   New UCA and CV installed with the suspension buttoned up.
    • My family still laughs at me when they see me drive up in the minivan. Same with less than a V-8 truck. It helps that I have choices. I don’t think I could only have a minivan as the one and only vehicle as much as I like it. And I wouldn’t pass up a good buy on an older V-8 reg cab GM truck. Could you live Raven as the only ride?
