Quick filter question (afe)
Hi all,
I bought an aFe CAI when my truck (‘16 5.3l) was new. aFe says to clean the filter every 25-30k. So I pulled out the filter tonight and it looks pretty dirty. But I couldn’t tell if it is a dry or oil filter. So I searched part number and online it shows a blue oil filter but this one is grey. Grey ones are dry. So I’m confused. How do I know if it’s oil or dry? Can I replace it with either one? aFe claims that a slightly dirty filter works best. Is mine ready to be cleaned?
thanks in advance,
HS
On 7/18/2019 at 2:25 AM, Homeslice said:
The dry filter with other brands is paper. The cotton ones get oiled and that sure looks like a cotton filter that the blue oil faded off of over the last 30k
Thanks everyone for the input. I figured it out with aFe. Apparently it must have been blue when it went in but they change color over time.
    rayredbone
    rayredbone
  • Who's Online   3 Members, 0 Anonymous, 402 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
