Slow start
    My truck is slow starting, it will turn over but has a hard time starting, once started it runs fine. I have had the battery alternator and starter tested
all are good and have passed. Wondering what else I should look into before taking it in for a diagnostic?  It is a 2000 GMC Sierra with a 5.3
If you turn it off and restart immediately will it start as normal? I had this issue with a 2001 Tahoe (slow start after sitting for an hour or so) and it was the fuel pressure check valve.
1 minute ago, Eddie Wilson said:
@damnthetorpedoes that does seem to be the issue.  Thanks to you and @rjgti I have some direction.
I don't think it was too hard to fix. I had good pressure, just would drain back into the tank when sitting and have to crank forever to get fuel to the block. Good luck!
Does it crank fast, but long until catch?
Crank slow and then catch.
The first is fuel related, check valve in pump is failing. Try turning key on for a few seconds, and then crank. It should catch immediately.
If the second, then battery or starter going.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 843 Guests (See full list)
