My 14 Silverado is throwing a cylinder 6 misfire code. This is now the 3 time with in a 1.5 month span it has been into the dealership to be repaired. They have replace all of the lifters and the cam, 4 fuel injectors and i replaced all if the plugs in it two days before it went to the dealer the first time and when you start it up after it has been sitting for a peroid of time it throws white smoke every where like it did when it smoked the cam. Everything has been covered under my warranty thankfully but even the dealer seemes to be stumped now. They have been communicating and running test with gm for the past week. Any ideas?
Thanks in Advance
So misfire and smoke? I would lock out dod and data log a scan. But any reason the harness wasn't metered out and the coil packs switched or replaced?
I would do a cylinder compression test. And find out about the smoke. Sounds like oil. But after those quick checks I would just get a over ride code and get a new engine installed.
I dont know if it is due to the dod since i installed my lift and new tires the truck doesn't activate the 4cyl mode any more unless im doing like 30 or below. I would love a new motor but everything is going through my extended warranty which only has 11,000 left on it
Maybe someone has a better idea. Something in my head is saying damaged valve or valve seat. Would cause a combustion issue I would if the knock sensor is picking anything up? White smoke is oil but where and how?
I have said this before but I will recommend it again. Just because you have the extended warranty don't be afraid to get a second opinion.
In my mind there is damage somewhere internal.
If they can scope it on get it in compression test inwould push for new motor but for peace of mind and time.
Oh yes you are correct. Been a long day. Ok then coolant. I would pull a plug and and scope it then possibly pull the intake and inspect. Not that the misfire isn't important but one issue at a time and the smoke is a bigger issue.
Even though its just throwing a #6 misfire it might be the head.
#PIP5498:
P050D P0300 Setting On A Cold Start
A vehicle may have a problem of DTC P050D setting along with a P0300 after a cold start up.
White smoke and/or coolant odor may come from exhaust for an extended period of time at cold start as well.
Misfires on start up only, with high rates always on one cylinder, can be suspect for coolant entry at the liner to deck face casting or the casting line in the intake port of the cylinder head.
Sent from my SM-G935V using Tapatalk
I've had a 2019 Silverado 1500 6.2 for 4 days and am getting a rough idle cold start and p050d code. 226miles. How can that be possible.
Something as basic as bad gas can cause it. Could also be a bad injector or just bad connection to injector. If you can check and see misfire count.
Sorry but I don't understand how the dealership can't figure this stuff out. Well that isn't completely true. I do they do care.and have never been equipped to do so they have enough knowledge to turn wrenches and swap parts.
True master mechanics start a shop and have to deal with everything and get it right the first time or it is out of their pocket.
With my device I can shut off injectors and check the bank or pulse width. Then by removing them I can flow test them with a a machine that cost 2 time my truck. Or for 60 buck replace them. So you know what they do. And that is fine but as you see it is like buying a lotto ticket great if it works if not how many parts you going to replace to get to the issue? That is why I said swap the engine.
His delearship is lazy. Troubleshooting procedures have been put out on exactly how to figure his issue out so I don't see why they haven't. I wonder if the dealer has even checked the head which GM has put out exactly how to do.
  • 4 years later...
  • 3 months later...
I have a 14 Silverado 5.3 with #6 cyl misfire. I did have a collapse lifter but with that being said. I also had a compression check, injector replaced, HP fuel pump replace while there, and still a misfire. Plugs and coil have been swapped. Only thing I can think of is a cam. Any thoughts to add?
    • Length/amount of data capture will be important to consider, sifting through 5 minutes of a data log can be enormous when it is stored in milliseconds. Being able to find the 'event' let alone decipher it.   Presumably the driver would notice something and hit a button to capture the 'window' of data. That window has to be large enough for the operator to recognize the event and react accordingly.    The data has to be able to be retrieved easily.   The data has to be able to be understood. Which is the biggest challenge, dealer techs won't even know what most of it is and would likely not even look at it if an owner brought it to them. Meaning the owner, the least educated/qualified, trying to understand it.    How will the data be presented? Could specific PIDs be selected and a timelapse graph be watched? How will a specific value be noted as abnormal? Additionally, a good data logger would be able to 'learn' normal values for a specific vehicle and flag abnormalities automatically. It could in theory watch parameters degrade over time and suggest maintenance as needed. (If the MAF reading begins tapering off for a given set of other readings - MAP, throttle position, Ambient, etc.. a flag to check air filter.) With the amount of data available, a device (really the vehicle rather than an additional accessory) should be able to do more than issue a DTC. It should be able to run the full diagnostic suite automatically and present a solution rather than a code. (It's not the 90's anymore). The technology is available for the vehicle to not just say "P0087", it should know low fuel pressure, check other PIDs to narrow down the problem itself, and determine if it is a lift pump, high pressure pump, regulator, leak in the fuel line, clogged filter, etc. Even if it can't narrow it down, it should be able to guide the user to the likely problems.   This would be a major problem for dealer service departments, which are the manufacturers customers it is in their collective best interest to NOT have this available to the consumer.   Further, if the owner is going to be the primary consumer of the data, it's got to be at a consumer price point vs. dealer only specialty tool price.   This group is more 'involved' in their vehicle than general public/consumer and will have knowledge, experience, needs and desires that are quite different from the market at large.
    • I put the prof up. If you read what I posted. You can see that housing, cars and income are in line with the era we were talking about. It’s harder in some places easier in others. Let’s agree to disagree and put this back on track, OK? We both are pretty stubborn and hard headed. But I bring receipts. If you wish I will not respond to you in the future.
    • Lets see if I can sum up two pages of nothing useful.    You want to refute your own governments data of the "Purchasing Power" Index FOR THE ENTIRE USA and its territories replacing it with the experience of a single family and its business and label that reality?  Then pound on that for a week hoping it will find traction?    Stan, I've told you several times. I don't do irrational. There are more people in the USA than your family.    I'm pretty sure this tread is so blown up. I'll give you a few days or months if need be to post yourself silent then I'll see if I can find enough parts of the train to reassemble it.
    • Facebook groups hate VSE, poor customer service; their responses to criticisms are pretty poor for a reputable company. I'm not a customer, haven't bought anything from them, but how they handle themselves on social media is a definite "No" for me.
    • $10,000 for a transmission?   Pretty sure I could buy all the parts, tools, and education to rebuild it myself for a quarter of that amount.   or swap it out with a new one...
