How to Identify Connectors
Hi folks.  I have a 2015 Sierra and am getting ready to make a couple of additions and changes to it.  I have been reading the posts about how to do most of them, and i "think" I'm okay, at least, so far, I am, but I do have one question.
How do I identify the various connectors at the underhood fuse panel and the panel behind the brake pedal on the inside of the firewall?  Many of the helpful posts say to splice into "wire 12 on connector x1" but I can't find which of the connectors is "X1".  I have downloaded several of the manuals from GM, and see that they also refer to a spoecific wire in a specific connector, sometimes even showing a picture of the connector, but I can't figure out how to determine which connector goes by which name.
Thanks,
JBP
What are you trying to hook up? I’d stay away from splicing if at all possible. Use add a circuits and tap into the fuse boxes.
get a subscription to the full-service manual for your truck.  It details what each pin on every connector is for, wiring colors, wiring diagrams, everything you would need for this.  I highly recommend it, particularly if you are going to keep the truck for some time and you want to diagnose or repair problems with your truck.
first to RacinDave.... I have to add a trailer connector wired to the ATA scheme, in that the turn signals are separate from the stop light circuits.  I have been told to rewire the trailer, BUT I have several trailers and several other trucks, ALL wired to the ATA standard.  I will be easier to rewire the GMC, then to redo all the others.
Now to Davester:  I have several downloaded manuals, as well at the GM Upfitters manual.  I have my issue sorted out, I will splice into the feed wire to the front turn signals and run a wire from each to the trailer connector.  From the manuals, I know which wires I need, but all the manuals tell me to find those wires in connector X1 at the left front fender fuse panel.  What I can't find anywhere is which of the five connectors on that panel is the "X1" connector.
I am certain that GM marks the connectors somehow, but can't find any such documentation.  I think maybe GM presumes that "everyone knows", but I assure you, I don't.
Thanks for the help guys, I appreciate your experience and time.
JBP
I don't know about the specific connectors you are talking about, but for my truck, GM color coded the plugs when there are multiple connectors in a row that are the same style (for example, the BCM in the cab, and the plugs at the back for the taillights), and the FSM has the color of the connector as part of the pinout description for each of them.
X1.pdf
FYI, these terminals are very easily damaged. Try not to twist and turn the connector while removing it. And DO NOT jamb a test light into the terminal.
Pin
Size
Color
Circuit
Function
Terminal Type ID
Option
A1 - B1
Not Occupied
B2
4
RD/GY
642
Battery Positive Voltage
I
1500
C1 - C3
Not Occupied
D1
0.75
YE
712
Left Headlamp Low Beam Control
III
D2
Not Occupied
D3
0.75
L-GN/PU
1315
Right Front Turn Signal Lamp Control
III
E1
Not Occupied
E2
4
RD/WH
342
I
1500
F1
0.5
GY/BN
309
Right Park Lamp Control
III
F2
0.75
GY/VT
228
Windshield Washer Pump Control
II
F3
0.75
D-BU/WH
1314
Left Front Turn Signal Lamp Control
III
G1
0.5
VT/GY
709
Left Park Lamp Control
III
G2 - G3
Not Occupied
G4
0.5
BK
150
Ground
II
G5 - H1
Not Occupied
H2
0.75
GY/D-BU
7538
Left Front DRL Control
II
Z88 with SLT
H3
Not Occupied
H4
0.5
WH
311
Right Headlamp High Beam Control
II
H5
Not Occupied
H6
0.75
D-BU/BN
7539
Right Front DRL Control
III
Z88 with SLT
J1
Not Occupied
J2
0.75
BN/GY
29
Horn Control
II
J3
0.5
BN/VT
2234
Front Fog Lamp Control
II
T3U
J4
0.5
WH
711
Left Headlamp High Beam Control
II
J5
0.75
YE
312
Right Headlamp Low Beam Control
II
J6 - N2
Not Occupied
Thanks Davester, I have several pdf"s which I've downloaded and never found anything about the connectors being color-coded.  Can you help me by telling me what colors the connectors are on the underhood fuse panel?
...or, if I am looking down at the underhood fuse panel, while it is mounted, which connector is which?  I am set, I think, with the wires that i need and which colors THEY are, but just don't know which connector they appear in.
Thanks for the help,
JBP
BEAUTIFUL, TBarn, I think that will help me quite a bit.  Thank you!!!
JBP
    timcpeters
    timcpeters
  • Who's Online   3 Members, 0 Anonymous, 1,246 Guests (See full list)
