Is this lift complete?
We are glad you are going to pass on it.
A 4" kit isn't going to put you in the poor house.
For true. Will pull the trigger on a zone or CST some day soon. Bilstein or eibach suspension level until then.
On 8/30/2019 at 9:18 AM, Grumpy Bear said:
Nice thing about a knuckle lift is the front end geometry stays with in factory. There is nothing to wear out on the knuckles but have them magnaflux checked for cracks and check the threaded holes and joint attachments for wear. Walnut blast and powder coat. If I were to venture such a lift this type of lift is the ONLY one I would consider.
These U bolts are not 'torque to yield'. Unless the treads are damaged or bolts deformed I wouldn't give reuse anymore thought that reusing my wheel lugs. Magnaflux them if you like. 100% of all materials failure start at the surface.
Shocks can be iffy but there are lots of replacements around. This level of inspection and restore of course means the selling price needs to reflect your cost of inspection & restoration. Otherwise just buy new.
That said. Lifts have penalties. All lifts.
not BDS lifts...0 downside from my 6inch lift IMO.
And to the OP...NEVER buy a used lift kit. If you can't afford new, then just settle for a leveling kit or nothing at all.  Lifts are a luxury not a necessity. Going cheap isn't worth risking your safety or the integrity of your vehicle.
And I would go with the Zone kit for sure, its a sister company of BDS (the best in the industry according to most).
That isn't a “ lift kit” its just a bunch of parts, hell it may even just be for a 2wd. Wouldn't take a chance to tear your truck apart only to find nothing fits.
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 534 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
