LTZ/High Country Exterior Accessory Part Numbers
Hi there, seeing if you guys could help me source some part numbers or maybe someone on here has them for sale.
Im looking for the Z71/HC Chrome Grille Inserts (The 3 bars that go across)
Z71/HC Window Sills Chrome
Z71/HC Side Body Molding
Chrome Door Handles
Going to have some polished wheels so I can plan on adding some HighCountry chrome to the exterior of my WT LOL.
Its all gloss black now.
00e0b2f45b9c4703b821135349695972_1601x80
Pretty sure they don't sell just the chrome grille inserts. I think you have to buy the complete HC grille.
  • 1 month later...
I installed the High Country Grill on my truck.  It ran over $600 if I recall correctly.
PN:  84056776
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
