'18 1500 wheel help.
Perseus
I'm looking at replacing the pedestrian wheels on my truck. I'm looking at Ion 171-8983p in 18*9 0mm offset with 5" backspace. I'm going to run stock size tires. Maybe jump up to 275/65 at some point. My question is (and I've got conflicting answers from 1/4" to 1 1/4" stick out past the fender) I'm hoping someone could provide some insight as to if these will sit flush, inbound or poke from the fender. Thanks in advance for any replies. Attached is the pic of the wheel I want to put on the truck
Sent from my Pixel 3 XL using Tapatalk
I think you'll get a little bit of protrusion out of the fenders. The 20" factory wheel that stays in bounds is 20x7. Going to 9" will stick out.
Edit: just realized the factory 18s are 8.5" wide, and mine definitely stay inside the wheel well. You might be ok. You could check yours with a tape measure and see.
Depending on where you live and local law enforcement's attitude about that, you may want some fender brush guards to cover it.
Sweet wheels by the way, man. Those look sharp.
Sent from my SAMSUNG-SM-J727A using Tapatalk
Lol if I trusted my own math. Ricer math tells me 1/2" wider wheel and 1/4" back space should mean 3/4" out from factory. On a 275/65 I might get a c hair of poke, but I want to be sure so I don't look like a tool
    • My son got a hatchback withe the aero package for like 17k new. Great little car with amazing MPH
    • Yeah, I've given up years ago with that! I was able to load a few when I first joined the site sometime around '07. Then after maybe 20 pics, it said I exceeded the limit. Now every pic I try to post says I've "exceeded 1mb".   ONE MB??? That's Windows 95 ******, lol!!
    • I get the same results with pictures. Then I figure it out. Then I forget. Screw it.
    • I guess I'm the only one on this forum who can't get effing pics to load here! Do you have to resize them to post, or am I just blocked from uploads?   I have the same luck with automotive electronics ... but this is the ONLY site on the net that I have this problem!   I'd post pics of what I'm working on ... but I CAN'T! 🤬       Just fabbed up the kickdown cable (had to extend the cable mount WAAAY out from the throttle shaft to get a full pull), and parts arrived for the fuel lines on the 940 carb conversion project. Should be able to drive this thing by the end of the day. If not for work, I'd have had this thing done SIX weeks ago.   Got the jetting sorted out last week. Had a real bad tip-in bog that I couldn't seem to correct. Friggin float height was over 11mm too HIGH! eBay purchase, so no wonder everything is screwed up right out of the box! I ended up with a larger dual-squirt accelerator pump jet anyway instead of the single. Also moved the 70 primary idle jet (4 sizes too big out of the box) to the secondary idle circuit, and installed a 57 in the primary. Runs great on the fuel bottle!    Still using the computer for ignition. Going to drive it first and see if I want to go through the project of installing an intermediate shaft with a distributor drive gear, so I can install a block-mounted distributor and run points, 100% computer free. I should do that anyway just from a simplicity / reliability / tunability standpoint. The electronics left me stranded last year a couple times! I can't tweak the timing to my liking right now because of the computer. Tried twisting the cam-driven distributor already ... and the damned thing just reverts back to where it was! That's infuriating. But if it runs well enough I might save that for next season.   Just driving it in and out of the shop to work on other projects, it feels 1,000% more responsive with the carburetor. Also fires MUCH faster when cranking. Can't wait to drive it and see if I got more than 114 ponies, lolol.   Hopefully these don't go 404 like the last post ... https://postimg.cc/gallery/MjhrmZS   Seems like that site went back to dial-up internet! Maybe they'll fix that some day ...
    • Triumph makes me think of cars not bikes. Especially with model names like the TR7, that was a Triumph car model too. Peak TR for me was the TR250. You could retain the post-war roadster looks, with an optional surrey hard top, but with an inline 6 engine instead of the TR4's anemic 4-cylinder, but still have a 4 speed, optional overdrive.   I know almost nothing about Triumph bikes, except that they exist. Good looking bikes though.   I don't know if I could just have one vehicle. The Silverado does it all except for fitting anywhere. But it leaves a void in real driving enjoyment, unless driving an extremely large sofa is your thing.   What did I do to my 'other' (muslce car - which one!?) vehicle lately. I took my '23 SS for a drive. It's only got 1600 miles. I keep reminding myself I shouldn't be so precious about this car. It likes to be driven. Needs to be driven. Life is short and if I don't enjoy it, someone else will. The other half calls it "the garage ornament".
