2014 Silverado AC colder on passenger side
Firearmjunky22
I’ve been having an issue with my 2014 where the driver side of my truck won’t blow cold ac. It blows ice cold on the passenger and medium on the driver. Both sides blow hot air without a problem. If I turn it to hot on both sides and slowly turn it colder, around 75 or so on the dial  the driver side stops getting any colder while the passenger gets ice cold. I’ve found that sometimes if I move the dial all the way through the temp range on the dial I can get the driver side to finally blow cold. But even when I get it cold it’s still 10 degrees or so higher than the passenger. Driver side is 58 and passenger is 48. I just had the ac condenser replaced a month ago. Truthfully I’ve never noticed if the passenger side has been colder since the replacement or not as I don’t sit over there.
