On 10/4/2021 at 10:44 AM, It's Tim said:
Most are usually making love to their phone so they wouldn't notice brake lights anyways.
Yep, hate seeing drivers on their phone when they are behind me. A light tint does give a nicer appearance but I am with the safety route.
