P/n request
Not sure what section this should be in....looking for the p/n of the small black plugs that go in the rear wheel wells.  They’re not visible unless you remove the rear wheel well liners and are maybe 1/2” diameter. Can’t find anything on gmpartsdirect.com
Are you looking for the plastic push pins?
Fender Liner Retainer Push-Type Clip A20991 For Chevrolet For GM 11589292 https://www.amazon.com/dp/B01H6HP8PG/ref=cm_sw_r_cp_apa_i_VncIDbDABM43A
https://www.dormanproducts.com/gsearch.aspx?type=keyword&origin=keyword&q=body-fasteners-interior&make=Chevrolet
No, I’m after some little rubber plugs that fill 3 holes in the inner rear fender. I pulled them to spray fluid film and they walked away.
