Tail light harness plug
Benstang
I’m wondering if anybody could get a picture of the plug for their right tail light harness in a 2014 or similar year Sierra. I just bought this truck and the passenger rear parking lights don’t work...I guess I didn’t look too hard before I purchased. The blinker, brake light, and backup light all work. I replaced the harness with another from rockauto.com, but the parking lights still don’t work.
The driver side plug plug only had three connectors (sorry, no pic) but the passenger side has 4...but the locations are different (picture below.) I want to compare with another to see if this could be the problem. Lightbulbs and fuses are all good.
Thanks, Ben
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
