2018 5.3 Yukon idle flutter at the stop in Drive
dvzzz
My first post and my first GM truck. Came to American trucks from the world of Japanese 8-cylinders. I bought 5.3 Yukon as used with 7500 miles on it, still in warranty. While I like how this truck drives the idle seems to be unstable.
Problem:
When I stop this 2018 5.3 4x4 6-speed Yukon SLE at the traffic while transmission is in Drive (fully warmed up engine) the idle is fluttering (feels like hear misses a beat, tach needle moves a tiny bit too).
I am sure that dealer will not detect anything or see anything and classify all is normal, however 2019 Tahoe 5.3 that I drove in is butter smooth. I am wondering if there are ways for me to narrow down the problem with idle. I know it could be dozens of things from leaky intakes to spark plugs or injectors. I hope this community points me to the areas to check.
Thank you in advance!
Its normal. Unless its going up by hundreds of RPMs don't concern yourself with it. I think its because they idle down so low, mine will go to about 500rpm, all the toyotas and nissan V8s I've been in idle up around 800rpm
This is a good point to know, 500 RPMs is certainly low. I have test-drove two other trucks in the past 5 days 2019 Tahoe 5.3 with 17 miles on odometer and 2017 Yukon XL 5.3 with 9,000 miles. I had to check if they were running on idle in D at stop, that how smooth they were, these engines can run butter smooth, I now know. I do not think mine fluctuates several 100s RPMs but it is very very tactile and noticeable, you actually feel like you are going over a bump except you are standing. This sensation is super unpleasant and my wife is now mad in this $59,000 truck, it reminds me of a Soviet Lada from 1980 era, except with those people were happy if they started at all.
Local independent ASE mechanic checked my truck and said indeed he felt it, no codes though. He told me "GM will wear you out on this one, they will keep sending you back with "no fault found" until you give up and trade-in the truck it is much cheaper strategy for GM than paying for extensive troubleshooting because, you will be losing money not GM". I like how quiet the truck is, the looks and want to own an American product if it is fixed but looks like nobody can win the battle with the mighty old GMC.
I am taking it to the dealer on Thu and let the games begin :)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
