Nitto Ridge Grapplers installed
MikeNH
275/65-18. Stock suspension and wheels. I'm real happy with them as there seems to be no noticeable increase in tread noise compared to the junk OE Goodyear highway tires that GM puts on the Z71. They're still a P-rated tire as I feel there are too many tradeoffs going to the E-load versions on a 1500 but they are definitely a lot stiffer than the OE tires. Bumps feel a bit more controlled. Snow is still a few months out but I plan to get some sort of tote box and fill it with sand tubes and it should be un-stoppable.
I love mine but I live down south and heard mixed reviews on their snow performance
Sent from Above
Sent from Above
Funny cause the two buddies of mine said they did great last winter. haha. I'll let you know in a few months I guess.
I hope they workout great for you and do post your experiences.
Sent from Above
Those look good! I think thats the size im going with on my burb since it doesnt change speedo much, and shouldn't come close to rubbing. Did you consider the 265/75/18s? That is my other option. Im afraid 275/70/18s will rub even with my level...
Sent from my SM-G975U using Tapatalk
I didn't. I mainly went with this because it worked on my 2011 and the suspension was basically unchanged from the 900s to the K2 trucks so I figured it was safe.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
