Rear Suspension Height - 01 Yukon XL 2500 4wd
Hello Forum, My left side suspension height was low on my 2001 GMC Yukon XL 2500 4wd. It's stock, and the truck only has 36k miles.
I raised the left front to match the right front via the torsion bar adjustment bolt. The height is now 36-1/8" to the left and right wheel openings.
I checked the rear and it's 38-1/8" on the right rear, and 37-5/8" on the left rear.
Is there a way to adjust the left rear leaf spring suspension height to match the right rear height?
Short of replacing the leaf springs, I don't see an adjustment.
Leaf springs are about the only way to level them out. Unless you have some type of shim made to go between the leaf and the axle. I don’t believe anyone makes them that small so you would have to probably have some made
Well, I would think a 1/2" height shim plate on the left rear leaf spring suspension would resolve the rear left-right suspension height discrepancy, but I only see degree shims.
I need to research this issue to determine if shims are available to just raise the left rear 1/2".
My 01 2500HD was sagging a small amount and was not level left to right, new springs are very expensive once you consider shipping.  I added a set of air lift 5000 airbags.  I put 5 psi in them, everything is much better, the ride was unchanged, it just gave a little lift to restore the springs to stock height.  The springs just sag after all this time.
Don't forget that fuel adds weight and the tank is on the drivers side. So when you get under half a tank or more it should become more level or may even tip the other way if you try to compensate for it with a full tank.
Yes, I've been keeping my fuel tanks full. I always top off at 3/4 tank, because I don't want to have to replace the two fuel pumps again after water condensation in the tanks corroded the pumps.
I should allow the fuel level to drop to 1/4 tank and recheck the rear wheel opening heights.
My owner's manual indicates my fuel tank capacity is 38.5 US gallons. Google says a gallon of unleaded gasoline weighs about 6 lbs. Therefore, my fuel capacity is 231 lbs.
If I burn-off 3/4 of my fuel capacity, that would only reduce fuel weight by 173 lbs.  That fuel weight is not just carried by the left side suspension. It's carried by both sides in
 proportion to the fuel load moment.
Based on that analysis, I don't think the fuel weight is causing all the rear suspension left and right  height difference.
The weight of a US gallon of unleaded gasoline is closer to 6.25 lbs. That equates to a fuel load of about 241 lbs.
The issue is that weight over the time span of when the truck is new. That extra weight over time has caused sag in the driver side spring. There’s many variables that can cause the lean. As also stated any time the truck is driven, you or someone is always in the driver seat. Thus adding more weight to the driver side. Over time causes sag and fatigue on the springs.
Should I replace the torsion bars and leaf springs due to the truck's age to bring it back to original spec?
I only have about half the adjustment left on the driver's side torsion bar as I do on the passenger's side. Also, a half inch spacer only  on the driver's side rear leaf spring seems like I'm polishing a turd.
I wouldn’t replace the Torsion bars as you can just crank them to lift the front of the truck. If the leaf springs and height difference are bothering you that much you can change the rear leaf. Or possibly add weight in the rear to the passenger side. Maybe it will bring it down level
    • I am new to this… but I saw some of your replies to another person doing the same as me… trying to replace the temp control actuator in my 05 GMC SIERRA, And can NOT get to it… how do I get the center console panels off, do I have to take ALL of them off to get to it? 80481681120__F97CE005-C5E5-4FBF-9589-1388214E3586.MOV
    • I will be one of those "blinded". One, I like new shiny things. Two, I've never kept any of them beyond the 3/36. Three, I don't finance anything. Four, yep, it's a waste of money....so,what? I'm doing my part of keeping automotive industry going and keeping my neighbors, most of whom are in it, employed. 😉      By the way this is the "signature... ¬
    • Although there is a "recommended" weight by those who sell trailers, my experience has been that they are way too aggressive in their information, for me at least. My '22 with 6.6 Gas, has a payload of about 3400 lbs and depending on your specs (I don't have 4WD so it has a bit higher Payload than others) yours will likely be different. Payload is one of the most important numbers for towing. Although you "could" tow the max trailer weight for your truck, I, personally, would not go close to that number. Having said that, a lot depends on how/where you will be towing. I live in the LMD of BC and often tow to Denver, Co, along interstates (flat and mountains) and I find I need to keep it in 5th (6spd) for the trip and travel at around 65mph. This is for a trailer dry weight of just under 3500lbs. If you are only doing local, short trips, it would not be that big an issue if you had a heavier unit. You will be surprised how much stuff you load the trailer with, so I would only recognize the trailers "full" GVWR weight rating, then decide on the appropriate trailer from that number. If you are worrying about how much stuff you should be putting in a trailer, you might have too large a rig from the get-go. Once again, depending on what terrain/distance in which you will be pulling. Marv
    • davester, Thanks for the response, how ever, I think I am now a bit more confused than I was before I posted - - After I posted, I actually found a YT video of a guy who replaced his Module (above tire) and he only disconnected the ground cable of the battery, but you describe rubbing the two cables together after disconnecting. I presume that is to do as you describe and eliminate any residual energy? - When I picked up the Module (between my posting and reading your response) from the dealer, I specifically asked about any re-programming and he stated it was not necessary as it was simply plug and play. Don't know how knowledgeable he is, though. - The video I watched also showed the Module plug to be difficult to "unlock" and remove, but there was no mention of silicone, although the video did show a bunch of dust/dirt in and around the plug (old truck) during removal. Are you talking about silicone that was applied by the factory, or silicone that you applied prior to plugging in? Thanks again, Marv
    • Looking for a clean, factory-style lighting upgrade for your 2022+ GMC Hummer EV? M&R Automotive's 40" Bumper Light Bar PRO features a vehicle-specific, bolt-on design with no drilling or cutting required. Choose a bright white or yellow main beam, both paired with an amber DRL backlight for a sleek OEM-inspired look. The kit includes a curved LED light bar, powder-coated brackets, and all necessary mounting hardware.    Learn more or order yours See how it installs and looks on the vehicle:
