Monroe Reflex vs KYB Gas-A-Just
hey guys I have a 2003 hummer h2, I want to get new shocks as I haven't changed mine at all. I am looking for the smoothest ride possible. I do not off road or tow. just normal city and highway driving. I'm kinda on a budget so don't wanna get Bilsteins or rancho.
I'm looking at these:
Gabriel Ultra (heard there stiff)
Monroe Reflex
Kyb Gas a Just
KYB Monomax (heard there stiff)
so I believe it's between the Monroe reflex and the kyb gas a just or anything else in similar price range. what do you recommend for the smoothest ride?
thx
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
