Resistors for LEDs
What does everyone run in their trucks for resistors on tail lights? I’ve ran through 2 sets this year and am wondering if I’m buying bad brand or wiring them up wrong. Any info would be appreciated
Send pgamboa a message on this, he builds the wiring harnesses for converting stock halogen tail lights to the nicer LED tail lights.  I just did the install and it came with nice resistors.  He can probably point you in the right direction or maybe even sell you some of the resistors he uses.
How are the resistors failing?
Assuming you bought resistors with the correct resistance and wattage, they should also be mounted on a heat sink, as they will generate a fair amount of heat during use.
The resistors I put in my truck have worked fine for the past 3 years or so, but I also had it easy, as my lights are in a metal box that made it easy to mount them it (as I have a cab&chassis with a flatbed).
They just quit working is all I know
Well, you have to figure out why they failed.  Vibration can break off the leads/wires, not mounted to a heat sink could cause them to overheat would be the main problems.
Try 100w 3ohm. They won't get as hot and should last longer. I've found the resistors to be hit or miss on lifetime. Some last year's some last days.
    Fishboat
    Fishboat
  • Who's Online   3 Members, 0 Anonymous, 617 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
