I ran into an issue this morning. I was on the highway going about 70 mph (flat terrain), the CEL came on for a few seconds (2-3 seconds), then went out. I noticed after that the truck wouldn't go into V4 mode like it always does.. It appeared to be running ok the following 20 miles or so to work, as I didn't notice any noises or power loss..it just would deactivate to V4..The CEL never came back on during the rest of my drive.
We'll see how it behaves on my ride home this afternoon..Do I have a problem? 2017 Chevy 5.3.. 43K miles.
You will need to get the codes read off and see what it complained about.  Most likely a miss fire.
The V4 will disable if your have cylinders reporting a miss fire.
My 2016 did the same thing when I had CEL but it was caused from washing the top end with GDI intake cleaner.
The truck didn't go back to V4 until after I cleared the codes.
I'm not sure if it will reset after a certain amount of time on it's own.
"Little known fact"; I've always wanted to say that. :) A cylinder can misfire up to 15% of the spark cycles before the driver will feel it doing so. 2X on a code read but explains why it could and it seemed to be 'running fine'. Just FYI.
I'd still see what code is set in the ECM.  Obviously something turned the light on.
I’m curious as well.. I’ll try to get the code.
Unplugged my MAF once and it upset my ECU setting off the second stage of the oil pump for the entire key cycle. Off and back on.....cleared the code and it never happened again. Ghost in the machine. Static spark? Computers, right?
  • 4 years later...
  • 8 months later...
So about a month ago I changed the spark plugs on my 2018 Tahoe Premier 5.3 4x2, 122k miles, had this truck for a little over a year now; I took a long drive to Tennessee and probably a week or so later I started to feel it stumble or stutter but there was no CEL.
A few days ago my wife and I were driving and she noticed the CEL was flashing for a few seconds then stopped; then flashed again then never came back on. Took it to AutoZone to see if the can find the codes or anything, and nada. Took it to a Jiffy Lube, and nada. They couldn’t find what it was. It hadn’t came back on since, until today I was about to make a decent trip to Kansas for work. Probably, about 100mi into the drive the CEL kept flashing, and it would not go into V4 and when I started braking it would “jolt” a bit.
any ideas? I’m basically chasing a misfire and maybe something else.
Scan for codes.
    Chris80s
    Chris80s
  • Who's Online   4 Members, 0 Anonymous, 906 Guests (See full list)
    • Still $3.01 with even more places at this price
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
