Just bought an 07, 5.3
I've learned 07's can have an oil consumption issue and depending who you talk to it can be cured by changing the drivers side valve cover or disabling the AFM using a "Range" or a programmer..?
Looking for the part number of the valve cover, best place to get them and ideas on the Range or what programmer I should be thinking about.
Thx
I have an 08 that had the same issues, Never installed the updated valve cover or the oil deflector in the oil pan, All I did was install a tune and turned off the AFM. You could still install the valve cover for peace of mind but GM never really knew what was causing the issue, they just tossed parts at it as they still do!
I used a Super Chips Programmer, but you can get a black bear mail in tune cheap as well or you can get a range disabler on Amazon or Ebay for cheap and be happy as well, but main point is turn off AFM and change the oil.
assuming you have a 2007.5 gmt900  not a 07 classic 800
i have changed the valve cover and it reduced what the catch can was capturing by half
installed the range @60,000 (lost 1 mpg)
now 132,000 and running fine
do a google search for the valve cover , plenty should show up
What is a decent programmer for the 07?
Is the Flashpaq 2865 any good, will it disable the AFM?  (One for sale locally for a good price)
Tying to learn.
Thx
Thx
https://parts-catalog.acdelco.com/catalog/catalog_search.php
Plug your VIN into that link for the right updated valve cover.  If you have the oil pan down you can install a diffuser that lessons oil consumption too.  Don't forget to clean or replace the VLOM filter that goes under the oil pressure sensor.  Best prices are often from Amazon via Prime, Ebay and RockAuto.  GM updated the VLOM and lifters making the system much more reliable.
The Range device should be considered a temporary measure, they sometimes break or cause computer gremlins.  A "tune" is the best way to go or at the very least, visit a tuner that can turn it off for $150 or so.
Tried that link, couldn't find the valve cover, woulda thought it would be under "engine parts" but would be pretty hard to list every part making up an entire engine.
Can you remove the oil pan with the motor in the truck?
Have been clicking around, it's my understanding a person only needs to clean that VLOM filter if their oil pressure gauge is showing low pressure?  Mine seems to be working fine and so far it doesn't seem to be using oil, it has about  94k miles on it.
Yes, you can remove the pan but it's a pain as you have to remove the front differential and cross member usually.  You're right about the VLOM filter, it can be cleaned and reused.  The rocker cover seems to be 12570427 as GM used different diameter PCV fittings between the earlier and later designs on the 5.3s.
Mine only used oil when I would regularly spin the motor up past 3500 rpms.  Since I am an old man and drive like one, it gets close to that in first gear only, usually.  Using oil with higher viscosity numbers (not weight) seems to help with oil consumption issues too.
Thanks for the info, will keep an eye on my oil consumption and see how it goes.
Picking up the Flashpaq 2865 tomorrow.
    250.3k
    chfkief
    chfkief
  • Who's Online   2 Members, 0 Anonymous, 1,603 Guests (See full list)
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
