Question:  My last Yukon Denali (2016) with heads up display had a screen that showed on the window, both the vehicle speed and the speed limit for that particular area in which the vehicle was located.  On my new 2020 Denali, with Heads up display, it has the same exact choice window displays, but none of them show the speed limit for the location of the vehicle.  Does anyone know if I need to do something to include this feature or has it been discontinued on the 2020 models?   Any advice or comments are welcomed.  Thank You....Rog
I believe the speed limit was from the navigation, do you have navigation?
  • 4 years later...
If I recall, for my 2020 the speed limit indicator for the area is a function of the On Star service being activated.
do you have a speed limit sign on the instrument cluster at all? If not then you more than likely need to just download an offline map and that area will have the speed limit postings for you. You can also use mobile hotspot on your cell phone to pair the truck up to it and have a data connection without paying for onstar. I'm not sure for the 2020's if it will work that way as I have the refresh model but that's what worked for me.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
