I'll see if I can find my invoice.
If I do, I'll post it.
Push them for a new radio.
Thank you Vicarod, will do!  They have wanted to me to bring the truck in but this is my busy time and hate to let loose of it.  They give me a loaner but it's just not the same nor does it have my tool box with tools I need occasionally.  I will push for new radio, thanks...
Our team is happy to add an additional layer of support between you and the dealership. If interested, please send an email to [email protected] ATTN:  forum username/GM Trucks with your contact information, VIN, brief description of your concern,  and preferred dealership. We look forward to hearing from you. To learn more about GM's privacy policy, please visit http://bit.ly/2h3ZUnC.
Aleigha W.
Just picked up a new AT4 HD on May 19/20. $92700(Canadian) truck. Infotainment system sucks balls. My wife and kids listen to me better. Not a happy customer.
  • Haha 1
This really is junk!  Mine is consistently inconsistent!!!  More often than not doesn't know what I am saying and asking for!  Previous trucks were so much better!  Comment about wife and kids was too funny...
Recently bought a 2020 Silverado LTZ, I'm having the exact same problem with contacts not syncing. Dealer has tried to fix it, but GM doesn't have an answer. Further, when I'm streaming  Pandora via CarPlay it will suddenly stop playing. Unplugging and reconnecting the cable doesn't help, only shutting down the truck works. This error message sometimes displays: "The operation couldn't be completed (Swift.Sting error 1)."  Anyone have this problem? The new infotainment system stinks.
Having same issue on my 2020 Silverado and having same issue, very frustrating. One time the contact is there, next time it is not.  Only way to get all the contact to show up is to plug in phone and use apple car play, which i dont always like doing.  Hope Chevy gets their act together on this, this should be simple.
Any further updates on this issue? 19 HC with the same issue today. I was talked to my wife and it showed her number but showed another contacts name. Many contacts were missing also. I “forgot this device” and repaired and that seemed to fix my issue for now.
I have a 2016 Yukon SLT and the IntelliLink constantly drops ONE phone number from my contacts, which happens to be the most frequent number I call.  Started about 4 weeks ago.  I have reset personal data, reset to factory settings, all of them.  Once I pair again, the number is there.  Two hours later, it’s gone.  Drives me insane.  Guess I’ll have the dealership pull their hair out over it.
Add another one to the list! A 2020 GMC 2500HD AT4. The truck itself is great but the "consistent" inconsistencies with the contacts pairing from my iPhone 11 is driving me nuts! This is simply unacceptable from a $70+ K vehicle. I get a lot of positive comments and inquiries about this vehicle, but this synching issue is the one thing I warn potential customers about when they ask about my ownership experience with this vehicle. GM really needs to get their act together on this.
I tried everything. Unpair, re-pair, etc etc. When I try to initiate the sync from the truck, nothing happens. When I try on my phone, the option isn’t there as it should be (and as it is on my wife’s Honda).
    B07
    B07
  • Who's Online   2 Members, 0 Anonymous, 701 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
