I'll see if I can find my invoice.
If I do, I'll post it.
Push them for a new radio.
Thank you Vicarod, will do!  They have wanted to me to bring the truck in but this is my busy time and hate to let loose of it.  They give me a loaner but it's just not the same nor does it have my tool box with tools I need occasionally.  I will push for new radio, thanks...
Our team is happy to add an additional layer of support between you and the dealership. If interested, please send an email to [email protected] ATTN:  forum username/GM Trucks with your contact information, VIN, brief description of your concern,  and preferred dealership. We look forward to hearing from you. To learn more about GM's privacy policy, please visit http://bit.ly/2h3ZUnC.
Aleigha W.
Just picked up a new AT4 HD on May 19/20. $92700(Canadian) truck. Infotainment system sucks balls. My wife and kids listen to me better. Not a happy customer.
  • Haha 1
This really is junk!  Mine is consistently inconsistent!!!  More often than not doesn't know what I am saying and asking for!  Previous trucks were so much better!  Comment about wife and kids was too funny...
Recently bought a 2020 Silverado LTZ, I'm having the exact same problem with contacts not syncing. Dealer has tried to fix it, but GM doesn't have an answer. Further, when I'm streaming  Pandora via CarPlay it will suddenly stop playing. Unplugging and reconnecting the cable doesn't help, only shutting down the truck works. This error message sometimes displays: "The operation couldn't be completed (Swift.Sting error 1)."  Anyone have this problem? The new infotainment system stinks.
Having same issue on my 2020 Silverado and having same issue, very frustrating. One time the contact is there, next time it is not.  Only way to get all the contact to show up is to plug in phone and use apple car play, which i dont always like doing.  Hope Chevy gets their act together on this, this should be simple.
Any further updates on this issue? 19 HC with the same issue today. I was talked to my wife and it showed her number but showed another contacts name. Many contacts were missing also. I “forgot this device” and repaired and that seemed to fix my issue for now.
I have a 2016 Yukon SLT and the IntelliLink constantly drops ONE phone number from my contacts, which happens to be the most frequent number I call.  Started about 4 weeks ago.  I have reset personal data, reset to factory settings, all of them.  Once I pair again, the number is there.  Two hours later, it’s gone.  Drives me insane.  Guess I’ll have the dealership pull their hair out over it.
Add another one to the list! A 2020 GMC 2500HD AT4. The truck itself is great but the "consistent" inconsistencies with the contacts pairing from my iPhone 11 is driving me nuts! This is simply unacceptable from a $70+ K vehicle. I get a lot of positive comments and inquiries about this vehicle, but this synching issue is the one thing I warn potential customers about when they ask about my ownership experience with this vehicle. GM really needs to get their act together on this.
I tried everything. Unpair, re-pair, etc etc. When I try to initiate the sync from the truck, nothing happens. When I try on my phone, the option isn’t there as it should be (and as it is on my wife’s Honda).
    250.6k
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 270 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
