Torque Converter, or whole Transmission?
dsr968
Hey all,
I have a 2014 Silverado 1500 Crew Cab LTZ 4x4 with the 5.3 and 6 speed transmission. The truck has a six inch lift with 35 inch tires. I am the second owner, I bought the truck in April of 2019 with 86,500 miles on it. I added a Borla ATAK exhaust, a Volant CAI and the 91 Octane tune with a Diablosport Intune I3 Platinum tuner. I have only put about 2000 miles on it since I’ve had it, with zero issues until now. I’m 51 years old, I baby this thing big time, so it hasn’t been raced, mudded or anything of the sort. Last Friday,  I was driving on the highway with the cruise set at 73. When I came to a decent incline, the tach shot up to about five grand like it had been put in neutral. When I tapped the brake, it stopped. Later in the day, I noticed the shutter that everyone refers to, at around 40-50 mph. Something else I noticed was with the cruise on at 73 or so, the tach would fluctuate between 1720 and 1780 or so, quite frequently. After reading several posts here, I am leaning towards the torque converter being shot. I had the fluid flush performed yesterday (not at my dealer, they are currently on strike) and added a 2 ounce bottle of the LubeGard Shutter Fixx.  Still having the same issue. Trans temp seems to be normal, I don’t have any leaks of any kind, so really at a loss here. I did reload the stock tune into the truck, so I’m curious if anyone has had issues with a dealer voiding their warranty. I need to take it back and get it looked at, but I’m really worried about the whole warranty issue. Any input and or advice would be greatly appreciated. Thank you.
I’m going to run it by a reputable transmission shop here in town tomorrow. Hopefully the news won’t be too bad. Keeping my fingers crossed.
see if the transmission is generating any codes (need a code reader that can get codes from the TCM).  the computer should notice if the torque converter or the transmission clutches are slipping.  you might also consider viewing live data for the rpm and transmission input and output rpms, to possibly see which is slipping.
Reputable trans shops are rare. There are many that can build and install them but the shops that know how to make them last and the tricks to them, there are few.
The adaptive part of the tune keep adjusting till it can't anymore. For most people they never know the vehicle has changed. For some they complain about shifting and the general feel being different.
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
