Rear Sliding window
My rear sliding window on my 2015 SMC Sierra SLT stopped working. Has anyone had this issue? First, I checked the fuse box (passenger side panel) but they’re no fuses in the location that diagram indicated (flat surface and no area for a fuse to go). Any advice as to what I can do to trouble shoot this issue? Steps and possible parts that I may need to replace. Thank u.
There is a recall in Canada.  You may need to see if the wiring actually melted on yours.  Also when the windows is open there are Contacts make sure they are clean and not bent down.
So, here is a strange question for you, do you have the wireless charging in your center console?
The reason I am asking is, the wiring loom for the rear window runs through the center console (floor mounted) and the wire can break/fray from the lid being opened on the console lid over time.
Not entirely sure about the charger, but everyone else who has had this problem had it.
Maybe check the fuse for it too.
    Fishboat
    Fishboat
  • Who's Online   5 Members, 0 Anonymous, 605 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
