LED bulbs
BigBill Roc
Hi everyone I want to change  my high beam, low beam, and fog lights over to LED's. I have a 2018 2500HD LTZ and would like any recommendations so i don't screw this up. Will I need canbus?
Thank you in advance, i just cant stand the yellow lights i currently have.
  • 2 months later...
As far as Sylvania goes. Sylvania Ultras are 20-25% brighter then their ZXE line.
The ZXE's are a whiter light,  but have less output and a shorter lifespan then the Ultra line.
Swapped my '15 to high quality (not amazon $50 crap) LED's. They'll put most HID's to shame.
  • 1 month later...
I'm running HID's for the lows, LED's for the highs, and LED's for the fogs. The HID's are much brighter than stock. The LED's aren't drastically brighter, but at least they don't look yellow next to the HID's.
  • 5 weeks later...
Definitely HID for the lows.  A projector upgrade would be even nicer and these headlights are a direct swap without having to split them apart.   This will be my next upgrade.
LED bulbs in fogs is one area I try to stay away from.  Fog light optics typically scatter the light pretty bad without any focus.  They may look cool but everyone else thinks your a douche.
An aftermarket projector fog would be nice.
