DEAL ALERT: Buy 6 quarts, get 6 quarts FREE Mobil 1 Synthetic LV ATF HP - Summit Racing Equipment
Summit Racing Equipment is running a special right now: buy a case (6qts) of Mobil 1 124715 - Mobil 1 Synthetic LV ATF HP and get 6 qts FREE! Summit P/N: MOB-124715
Mobil 1 Synthetic LV ATF HP 124715 is the new "blue stripe label" automatic transmission fluid designed to cure the shudder issues in GM 6, 8, and 10 speed automatic transmissions. It meets GM Dexron HP specs and exceeds requirements for previous transmission fluids like Dexron VI and III.
Note: you may need to add the 6qts to your cart before the "get 6 free" offer appears.
Nice!  If you add one 6 quart case to your cart it asks you to select a second at no cost. Shipping still applies unless you order something else to qualify for free shipping. Even without that, it's a great deal.
Nice find, and thanks for sharing.  Was thinking about changing out the fluid again even though I’ve already had it changed to the new formula.  Transmission hasn’t been acting right lately and am wondering if another fluid change might help.
Works out to be $7.00 a qt.  Not to bad a deal.
I remember when shipping was free over $50.  Man have times changed.
Mobil 1 p/n 124715 is the latest formulation and it supersedes p/n 112980 which is the old black label bottle.
