I use manual mode when towing our camper as well (especially in the Colorado mountains)......but I've yet to find a use for the "1" mode, which holds the transmission in first gear. How about you?
Grade braking control.
If you're going down a steep hill while towing, put it into that "1" position.
The truck will work it's hardest to hold whatever speed you were at when you selected that position. Expect for some high engine revs[emoji6]
But it truly works brilliantly
Sent from my SM-N975W using Tapatalk
The truck will work it's hardest to hold whatever speed you were at when you selected that position. Expect for some high engine revsemoji6.png
I've used manual mode for grade braking quite a bit. Been down plenty of high altitude passes at 5k RPM, with my camper trying to shove me off the mountain, haha. It works great, but I've seldom had to keep it in M1 because first gear is so low. I still don't understand the purpose of forcing it to hold 1st gear only. Why not just use M1, and tap the shifter button when needed?
That's just it, it doesn't go to first gear, the truck will do what it needs to to hold the speed you're at once you put it into that "1" position. It'll drop gears as it feels necessary from the current gear you were in, to hold your speed
Hmmmm.....that's interesting. I didn't know it behaved like that. I figured it would just slam into first gear and stay there until you shifted it yourself. I guess I need to play around with it more.
  • 3 weeks later...
Yeah [emoji16]
Now, if you put it there from a stop, ya... it won't want to shift up [emoji6]
  • 2 years later...
Hey MAKKAT did you ever figure out the second 1, if not, It is your current gear as your driving while in Manual mode. If you select gear M4 while going 0 miles the transmission is in 1st gear and will show 1, as you drive to 40 mph for example and the trans shifts through the gears to 4th it shows what gear your currently where that 1 your asking about is........
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
