Tire fit
Hi guys, I’m new to these forums so if I do anything wrong let me know! I have a custom 2018 Silverado crew can. I’ve had a rough country 2.5 leveling kit installed and was wondering what my max tire size would be now. I believe at the moment I have 285/45/20. I would like to offset it a little so it comes out a little past the fenders but just barely.  Anything else I should know as well before?? (I don’t want any trimming or rubbing)
That's a really low profile tire. Are you wanting a higher profile? Because that will affect how big you can go without rubbing. Your tire now is roughly a 30x11x20.
And do you have a 2wd or 4x4?
Sent from my Pixel 3a using Tapatalk
Yeah! I was looking for something all terrain that’s higher and more aggressive looking. Ideally I’d want to close the gap as much as possible. I just don’t know what would be the max without causing and rub. 2wd
Thanks man! It definitely helped a ton!!
No problem! Good luck. Post pics when your set up.
LRod
