Hi everyone, my 2019 Silverado seems to have a shudder/ vibration when cruising on the highway. This happens quite often on my drive to work and back. I put the truck on manual mode and didn't allow it to get into 8th and the shudder/vibration was gone. When I took it into the dealer to have it looked at they called it normal operating but the loaner they lent me had the same issue.  I came across a service bulletin for 2018 Silverado's that called out a transmission fluid change to help with a shudder issue with the torque converter. Has anyone experience these issues and tried this service bulletin or have a different fixed that worked? Any help is greatly appreciated.
I should also add the vibration occurs when the truck has some minor resistance like a flat or slight grade and stops once the truck down shifts or AFM shuts off
Update just heard back from the dealer. They could not replicate the vibration, which is surprising because it literally does it every drive on the highway. I'm going to give another dealership a shot. Does anyone know what the truck uses to determine when DFM should turn off?
I've heard a couple guys have issues with specific sections of bad roads. Can you replicate it if you drive other routes besides your normal commute?
Also, which trim/ engine/ transmission do you have? What's your build date?
Yeah, it happens on almost all of my drives if they involve highway. 19 LT Z71 with the 5.3 8 spd transmission and If I remember correctly a 3:21 gear ratio.  I'd love to know what tells it to go back to 8 cylinders, I imagine it would be rpm. I'm wondering if something as simple as a slightly bigger set of tires would cause it to get out of DFM mode quicker and reduce the shake.
Mine does a similar light shudder when you have your foot barely on the gas. It can do it from 30-40 or from 60-65mph. Change throttle position and it goes away.
I test drove a 2018 Sierra SLT 5.3 with the 8 speed yesterday at a Toyota dealership and it did the same thing. The salesman was sitting in the back seat and I asked him if he felt the shudder, he did and wondered what it was. I thought it was occurring when it dropped in 4 cylinder mode so I put it manual mode and 7th gear and it continued to shutter every few seconds.
There is a service bulletin for 2018s that changes the transmission fluid to help with a torque converter shutter. On my 19 if I put it in manual 7th it won't shutter/vibrate, I don't think it goes into DFM at that rpm on the highway.
Take a ride with the tech who is working on the truck to show them what you are talking about.  Few times I have had to do this to avoid the dealer saying they could not find anything.
our 19 6.2 10 speed does the same thing, dealer drove it and said can not replicate and normal. Watch the tach bouncing around when it happens...definitely an AFM issue. hate it on these new trucks.
I am having the same problem with my 2017 Silverado.  It has 28,000 mile on it and I think 20,000 is from it being in the garage.  The dealership that I bought it went out of business and I had taken it to another.  They said they put a new tourque pump in it.  Well the problem is still there!  so I went back and told them and they said bring it back in on Dec. 13, 2019, so they told me to leave it in the morning and they would try something else!  I thought I would take the mileage off when I dropped it off so I did. (this was at 7:45 AM)  3:00 came and I called them and asked about if it was done,  they stated(yes to come and get it)  so I went to the dealership and they told me they couldn't find anything wrong, to come and get one of there trucks and drive it and see if it does the same thing (not sure why other than sell me another truck)  When I got in my truck and checked the mileage it had the same mileage that it had when I parked it !  I called them and they said that they seen the machanic going with the keys!  Really frustrated !!!  They said they would take it for a ride when I came and drove there truck.  Well that isn't going to happen.  I am not sure what to do next or who to contact !!  any advise .
I'm calling another dealership today to give them a shot.  The dealership I bought the truck from doesn't seem to interested in trying to fix anything.  I will post how this trip goes.
Its AFM / DFM its a know issue. The computer activates AFM / DFM, the cylinders deactivate, engine trans start to vibrate and shutter. Its all garbage and nothing avail to deactivate it. If i put my truck into AUTO instead of 2WD then its does it less, the engine seems to not want to go into AFM / DFM every god darn 5 secs in AUTO
Quick heads up. No dealership is gonna be interested in fixing anything. You'll get better customer service and satisfaction by going to Taco Bell.
  • 9 months later...
Jeffrey, I have the same issue with my 2019 5.3 8Spd. Only difference is i had the flush done and it made it worse. Have you found any resolutions?
Edited by Stratman
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,255 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
