2020 GMC Sierra SLT
Dave Taylor
 Are you positive it came with one?  Are you driving a Duramax?
On 12/15/2019 at 1:45 PM, Dave Taylor said:
Just bought a new 2020 and can’t find the block heater. There is a 3 prong plug under a small cover cap on the drivers side. Not sure if that is the block heater cord.
If you talking about low and just ahead of the drivers side front wheel, then that's it.
Page 215 of you manual has a diagram showing location detail for both LD and HD Sierra.
Should have come with a cord that matches.
  • 2 months later...
Dealer had to order the cord for mine, was not in the truck.
But it did come with the winter cover without the camera hole....lol
The guy in pdi probably has a stack of them
On 3/5/2020 at 2:42 PM, Likarok said:
I think you should have bought a Ford!
They still make trucks?
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 831 Guests (See full list)
