Well, this is frustrating...what to do...
Truck runs fine...lifter will sometimes tick loud enough to hear it with the windows down and the next time it is non-existent. I'm kinda hoping it's a deposit issue and changing oil brands will clean it up...might try a bottle of AutoRX (if they still make it) and give that a whirl.
For now, I'm just going to drive it...
Sent from my SM-T350 using Tapatalk
Ok, update time...
I've got a new toy that I've been driving more than the Silverado...so not many miles getting put on it at the moment. It's more fun to drive a 30 year old truck with a tractor engine...
For a little more background, I ran this truck for the first 25k or so on Mobil 1 5w30, then used up a couple 5 gallon pails of Schaeffer's 5w30 Series 9k, went back to Mobil 1 for a stretch, and recently was trying Miles SXR synthetic 5w30 (had good reviews, BITOG spoke highly of it, etc.) for about 15k miles. So the oil change mentioned above was back to Mobil 1 5w30 (I have it for the Equinox), and it was still tapping with the Mobil 1 initially. Fast forward probably 2500 miles and I'm back to normal: no tapping, no weird noises, nada.
For those interested, I did cut the filter apart, and it was clean...nothing in the pleats whatsoever.
My guess is the Miles was leaving a deposit that the lifters didn't like and by changing to Mobil 1 the detergents changed and removed that deposit and thereby eliminated that lifter tick. The Mobil is still clear/clean on the stick, so if it was a deposit; it wasn't much.
I've got another five gallons of Miles, I'll keep it for the OPE and keep the truck on Mobil or Schaeffer's (I'm going to be ordering stuff for my old truck from them, may go back to them for the Series 9k 5w30).
Sent from my SM-G950U using Tapatalk
  • 3 years later...
Ok, so rising from the dead...
I've had this low RPM/idle tick a while now...I have 220k on the clock.
Just this week it has gotten louder (or maybe more annoying?).
The only thing that changed recently (like last week) is that I went from Mobil 1 5w30 to Mobil full synthetic 5w30...I'm almost wondering if the viscosity is breaking down or just less with the full synthetic than the Mobil 1.  I'm going to try getting some Mobil 5w40 (like that European Car oil)...I'd try 5w40 diesel, but I don't want to take a chance of poisoning the cats (although I think Rotella is dual rate CI/SI)...
So it's still kicking...doesn't occur a anything about about 1200rpm, it just fades out and a quiet engine.
Oil pressure.  Have you tested it with an oil pressure gauge just to have a good idea what its making?
My guess based on the two 6.0s we've seen at work is all the lifters and guides and probably a new cam.  One was a 143k mi truck at work and I think it might have spun one in the bore and it wiped out the lobe it was on.  Another was a NYS Trooper 5.3 (AFM engine) that had a non AFM cylinder that wiped a lifter and lobe.  It would tick pretty good but once you spun it 2500+rpm you'd have sworn there wasn't a thing wrong with it.  Smooth and quiet.
So ballpark, what would is cost to open this up and replace the cam/lifters?  I got a verbal quote, but it seems excessive and like they don't want it.
Probably do a oil pump and water pump at the same time...
Just got back from a 3600 mile run to Cheyenne and back, truck got 14mpg out pushing a headwind and 17mpg back...runs like a top.
Hard to say for sure because everyone labor rate is different but I bet a shop would charge $3500-4000 to do it based on the book time.
Anyone that has done a few of these engines could have it stripped down and ready to assemble again in less than 8 hours. Even less if you used power tools and everything came off clean.
I still say you have either a broken or loose stud or a cracked exhaust manifold.  If you dont have dark oil with some sparkles in it, your lifters are not coming apart, or wiping the cam.  If you loose a roller lifter the carnage is immediate.  A wiped cam lobe sound never goes away, and they run bad.
Can't be a manifold, both have been replaced (manifold, gaskets, donut seals, and bolts) with no change...
Lifters get weak, that's nothing new...
Lifters get weak?  There is nothing to wear out.  They are hydraulic roller lifters, oil pressure keeps the piston cup inside the lifter pumped up.  There could be debris or an oil restriction keeping them from fully pressurizing, but that kind of contamination would show in your oil.   If a roller goes, it can ruin the cam, but it will put alot of metal into the oil, and will make a racket.  And the truck will run poorly.
Edited by vucelick
  • 5 months later...
I had an issue similar to this and changed my oil filter to the K&N filter (white one with the nut on bottom). After changing the noise went away. I found the Mobil 1 filter restricted the flow more than the K&N filter.
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
