Does anyone have the install instructions for OEM DVD Headrests for the 2017 Silverado HD? They do not come with instructions, no videos on youtube, no pics on the web or instructions on the web. Dealers don't have instructions either and want to charge me $800 to install them. PLEASE HELP!
Do you have a part number?
did you buy the parts online and take it to a dealership to install?
I’m having mine installed for $220 by the dealer. They said they have the install directions but they wouldn’t share them with me.
You shouldn’t be paying $800. The install price is right on GM’s website.
I have the install directions that @tbarn sent me.  Its a huge file so it needs to be emailed.  The printed directions are about 35+ pages.  This is because the Trucks and SUV's are in the same install directions.
If you bought the correct K2xx headrest kit, you can install it your self with out any issues.
  • 4 years later...
I know this is an old post, but just got a set of dvd headrest and would like to self install. Anyone out there with a copy of the install manual they can email me? Thanks in advance.
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
