My 2018 2500 Ram beat me to death.  My new 3500 double cab long bed with snow plow package rides like a Cadillac compared to the Ram.  I guess it's relative.
Does the Heavy Duty Front Spring /Camper Package also include heavier duty springs in the rear? What I am reading is only about heavier duty springs in the front. Thanks!
It only changes the front suspension.  You often go over FGAWR on the camper calculation that is why some models say not recommended without the heavy front suspension option.
#iworkforGM
Thanks for your response. That makes sense. I did not include it in my truck build but was researching more and was curious.
Are the torsion springs an easy replacement that one can do without a lift?
Here is a youtube video showing what’s involved for an earlier generation truck. The job on the new ones would be similar I assume.
Changing torsion bars on the new trucks is the same as the older trucks shown above.  There is a new tool for the newer trucks because the bars are heavier and the cross piece is thicker requiring a bigger tool.  The bars are really hard to remove once the tension is off of them.  I found that renting a rotary hammer at a tool rental is the best way to drive the bars out of front A arm.
Edited by unit
My 3500 has that camper/plow  spring package and it rides just fine. its almost as smooth as my '16 2500 with Fox shocks on it. I was worried but that frame soaks up the ride bumps. I have 60psi in fronts and 70psi in rears.
I took delivery of my new truck yesterday GMC 3500 SLT CC LB SRW gas engine 18 inch wheels with front camper springs (not snow plow package).  It’s noticeably stiffer than the ones I test drove without camper springs but not at all harsh when driving empty.  What I most notice is increase lateral stiffness turning corners (which is what you want for a camper).  I've been driving around so far at the tire pressure the factory or dealer put in it, 60 front 80 rear, which is the door recommendation that supports full load. Sticker payload is 4,053 lbs.  Two tons for the price of one!  I’ll likely run a bit lower pressure but haven’t messed with it yet.
Another JR, I run the rears at 70 PSI when not towing to soften the ride somewhat. Yes its lower than the door sticker but why would you put more air in the rears when there is less weight back there? I think its because thats how GM has to meet the GV specs for the truck. Not needed on a daily ride but I will air up when towing. Of course the nanny in the truck shows low.
I dont get a warning in the vehicle but if I go to my GMC app it says low pressure in rear. So I am not worried. if I went to 60 PSI I might get a warning on the truck display.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 1,213 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
