Baldeagle
Hey GM forum, Since I live in Florida I disconnected the coolant line to the throttle body but not sure how to cap off fitting in front right head. Thin rubber cap just cracks after a few thousand miles and leaks. Do they make a cover for both openings in heads? Thanks
Um.... I think you are referring to the cooling line that comes off the steam pipe on the heads.
That is needed to remove air from the cooling system.
That being said, you can get some caps like in the rear of the head and put them on the front of the cylinder heads and remove the pipe. It's your rig.
