Amp step install question
lapoolboy
Can someone with Amps please confirm the motors are clocked differently on each side of the truck?  Seems odd to me each side is different.  The motors won't fit in any other orientation so I'm sure it's correct...just want to confirm.  Passenger side on the top, driver's side on bottom.
Threw me for a loop when I was installing, but that’s how mine are too. Pass side motor points inboard toward the frame, driver side motor points up.
Thanks bud.  Just didn't look right!
I didn't rush by any means and it took me about 4.5 hours.
Very easy install, I was impressed with quality of parts and how complete the kit is.
Only suspect items were the wire ties, they were pretty cheap.
VERY HAPPY with the steps.
Tom
Yeah, bolting the actual steps on is the quick part. Running the harness correctly and cleanly, not so much. All told I was into it about 4 hours myself.
Am I the only one that had problems drilling the pinch weld for the LED wiring to go thru?
I have good drill bits and it took forever and dulled two bits completely.
Tom
Tom
I refuse to drill holes in my new truck and open up sources for rust.  I just mounted the lights on the vertical side of the pinch weld and wrapped the wire under and behind and secured with the stick-on cable tie mounts.  Looks very clean, no holes drilled, and the light is pointed right at the steps to illuminate them.
got a pic?
    Patrick Fergy
    Patrick Fergy
  • Who's Online   4 Members, 0 Anonymous, 924 Guests (See full list)
