No low beam Headlights... HELP
GhettoSled
I have a 2014 Silverado. About three weeks ago, I noticed the driver side headlight was a little dimmer than the passenger side. Then, about two weeks ago, the drivers side went out. I could get it to come back on if I turned the auto headlights off, then back on. A couple of days ago, BOTH low beam headlights went out. I thought it could be the bulbs, so I replaced them, no luck. So today, I replaced the headlight relay and the 10 amp, 3 pin fuse hoping that would work and nothing. My high beam and fog lights work, but I'm at a loss for fixing the low beams. What could be wrong?
Disconnect the low beam plug from the bulb and with a volt meter see if you get power when the switch is turned on? If you do then the bulbs are the issue.
If you dont get power then test your fuse with the volt meter. Basically trying to see where you are loosing the 12v power in that system. Could be the switch perhaps? test that as well.
