Possibly bad injector?
pajkrubi
Hello everybody, tonight while driving my 2014 Silverado with the L83 5.3 (102,000 miles) my check engine light started flashing and the engine had an obvious miss.  I pulled the code and got a P0305 (cylinder #5 misfire). I drove it gently home and checked the plugs and wires. I just recently did new plugs and wires (factory AC delco iridiums and taylor street thunder wires) so I didn’t know if one came loose. Everything was tight so I pulled the plug. The plug looked nice and clean with no broken electrode or anything obviously wrong. So I swapped the coil pack from cylinder 3 and took it for a short drive until the cel started flashing again. Got it home and it still said cylinder 5 misfire. I swapped the plug and cable from cylinder 3 then just to see if the inside of the plug or cable was broke. Came back still showing cylinder 5. The plug also seemed dry for not firing so I started to wonder if it’s fuel. After searching I see the direct injectors in these motors are pretty much garbage and fail regularly. Do you guys think it’s probably the injector or could it maybe be a failed lifter from the afm? I’m hoping it’s an injector because I’ve watched a few videos and it doesn’t seem horrible to do. I’m pretty mechanically inclined and have all the tools. I’ve read about the teflon seals but saw a few tricks to get them on. Also if it’s an injector I’m thinking about just replacing all 8 since you can find them for pretty decent prices online. I also know about needing to replace the hard lines also and will be doing that. What does everybody think? Most likely an injector or is it something much worse like a lifter? Side note and not sure if it matters but I’ve ran E85 for about the last year or so in it but seeing as how it’s a flex fuel I don’t that would matter. Thank you for any help you can give.
Ok thank you. I kinda figured their would be a pretty loud racket if it was a lifter because the push rod would be loose. Thank you
